I've only had my Ionic for less than a month and it doesn't work anymore! It does not charge-- tried charging with USB port; tried charging with wall charger; tried charging thru desktop/laptop. No light to indicate any power. It's practically still new!
04:50
09:03
08-27-2019
04:50
09:03
Hi, @jeescalante, have you tried cleaning the charging contacts? Here’s how:
Also, sometimes folks think that their Fitbit isn’t charging when it has actually simply become unresponsive. This can happen particularly if the battery has been allowed to die completely. So once you have cleaned the contacts, put it back on charge (a wall charger is fine as long as it is UL/ CE certified - the charging plug that originally came with your cell phone is ideal, as long as it will accept a USB cable). Give it a good 2 hours charge, even if it does not seem to be charging.
When it has been plugged in for two hours, give it a restart:
You may need to repeat the rstart a couple of times, but with luck it should spring back to life.
If this procedure doesn’t work, please post again and a moderator will be along to let you know the next steps to sort this out for you.
Welcome to the forums!
