12-12-2017 18:39
12-12-2017 18:39
Hi,
since i did the firmware update, the lighting of the watch is no longer
activated by the motion of the hand to watch the time.
Is this a bug in the update? am i missing something?
Best Answer12-13-2017 04:03
12-13-2017 04:03
@philsansfil You might need to set the Screen Wake to “auto”. Swipe left to right on the clock screen to bring up the settings and see what it shows for Screen Wake. If it shows manual, tap it to change it to auto. That hopefully will fix your issue.
Best Answer12-13-2017 02:37
12-13-2017 02:37
@philsansfil Hey Phil,
I assume you tried restarting the watch by holding the left button and the bottom right button until it resets?
Barry
12-13-2017 04:03
Best Answer12-13-2017 18:54
12-13-2017 18:54
Thanks a lot. That did it! P
@SunsetRunner wrote:@philsansfil You might need to set the Screen Wake to “auto”. Swipe left to right on the clock screen to bring up the settings and see what it shows for Screen Wake. If it shows manual, tap it to change it to auto. That hopefully will fix your issue.
