03-25-2019 00:35
03-25-2019 00:35
my Fitbit ionic's step counting is stuck
I have restarted more than a dozen times, changed clockface, and restart some more
It has been stuck on 19682 step for 2 days now
Best Answer03-25-2019 00:56
03-25-2019 00:56
As the restart isn't working for you then you could try turning the fitbit off and on:
On your watch, open the Settings app > About > Shutdown > confirm the shutdown.
To turn your watch back on, press the back button.
Best Answer03-25-2019 01:05
03-25-2019 01:05
i meant to write on my post that restarting isnt working...
Best Answer03-25-2019 01:09
03-25-2019 01:09
The shutdown process I mentioned is different from the restart. Just in case we're getting confused over what the restart is, here's fitbit's notes:
