09-06-2018 15:04
09-06-2018 15:04
So, I fell tonight while running. Ran on some rough road I guess. A few nicks and scrapes on the metal case around the Ionic face, and a slight scratch on the face surface. Any suggestions for touch up?
Best Answer09-06-2018 15:19
09-06-2018 15:19
Ouch! I believe the screen on the Fitbit is version 3 of Corning's Gorilla Glass. You will have to decide if any of the methods to repair the scratches are worth the possibility of making it worse but a couple of things you can try without harm is a Magic Eraser.. just rub continually and see if it helps. also a white pencil eraser and rub it slowly and steadily across the surface.
some people claim toothpaste, corn starch and all kinds of stuff.. the 2 I mentioned are fairly common and accepted to work.
Lastly, it would be a drastic measure but you can sand and re polish just like a faded headlight but I would really weight out this option. Best of luck!
Best Answer09-08-2018 13:06
09-08-2018 13:06
Magic Eraser might be a safe option? Thank you!
And thankfully no no harm to my Fitbit. I should be back on the road in a day or 2. Thanks for your reply!
