03-31-2018 02:20
03-31-2018 02:20
Since doing the update last week am unable to just have the manual setting for clockface, hence in bed it lights up every time I move and is keeping me awake
There used to be a manual setting on the settings but I cannot find it anymore
As a menopausal female with sleep issues this is unhelpful and last night I ended up taking it off
03-31-2018 04:16 - edited 03-31-2018 04:18
I think I know what you’re looking for:
1. Press and Hold the LEFT button.
2. Depending on how you have your Ionic setup, you may need to slide to the left to access the RIGHT screen.
3. SCREEN WAKE, should be visible and available for you to set!
4. Short Press the LEFT button to return to your Clock Face.
Hope this helped and keep on STEPPING!
Gunny | Richmond, VA (USA)
Ionic Adidas Edition, Versa Special Edition, Aria 2 & Flyer | iPhone & Windows 10
Take a look at the Fitbit Help site for further Assistance & Information.
03-31-2018 04:22
03-31-2018 04:22
Thank you, Hopefully that will be fine now
Just now need to learn to switch GPS on, wondered why my parkrun was 0.25km short!
03-31-2018 04:30 - edited 03-31-2018 04:31
You will find the GPS setting in your EXERCISE App. Once you open that, go to the Exercise you want to use and access the setup icon (top left corner). In this area, scroll down till you locate the GPS option.
