01-15-2022
15:09
04:34
01-15-2022
15:09
04:34
Got my new Fitbit luxe and happy with the size and feel but disappointed with the available clock faces. I have to squint to see my steps and the only face with large steps option is hazy. Out of the many faces only 3 stand out the rest are similar and not as pretty as the tracker itself. Is there no way to give more clock face options ?
01-16-2022 18:50
01-16-2022 18:50
Completely agreed...I thought this was a tracker.
01-23-2022 09:29
01-23-2022 09:29
I can't seem to find a face where I can read the steps even if I put my reading glasses on. I like the look of the Luxe but may return because of this issue. Does anyone have a solution that I may have missed?
01-25-2022 05:28
01-25-2022 05:28
I am looking into buying a Fitbit and looking into the forums to learn more. I'd really like a Luxe but the clock faces might actually be a deal breaker: there is not a single one that shows me the time (horizontally!) and my steps and heart rate. Then again, the Charge 5 only has one face that does that, sort of. It's all design over content and functionality. Currently using a Charge 2, which as a decent clear and simple to read clock face. Surely the lack of info on the clock face should not be the reason that I won't buy a new Fitbit!!?
01-26-2022 04:27
01-26-2022 04:27
I brought the luxe and honestly wished I didn't. It may be stylish but it not the best tracker. You have to swipe to see your steps. The clock faces are such a disappointment. Check out the charge 5 as an alternative.
01-26-2022 05:11
01-26-2022 05:11
@phoebe255f I have the Magazine-C clock face and it shows steps and time without having to swipe. You can tap it to go through date, heart rate, and active minutes. Whichever stat you had showing last will stay on there, so steps can be seen at any point.
