12-21-2021 15:41
12-21-2021 15:41
I have had my Luxe for about 4 or 5 weeks. It worked fine until a week ago. The battery went dead after 3 days of it's last charge. According to the paperwork the battery life is supposed to be 5 days in between charges. Tonight, makes the 3rd consecutive night that I have to charge my Luxe. It also is not tracking my sleep patterns or times. I am not happy with the Luxe. I wish I never ordered it.
12-21-2021 19:11
12-21-2021 19:11
If you use GPS or have “always on” display activated, that can zap your battery pretty quickly. Some other tips for battery life are available this help article Can I extend my Fitbit device's battery life?
You can also try resetting the device to see if that helps.
- Swipe down from the clock screen to Settings and Restart Device > Restart
- If the above doesn’t work, connect to charging cable and press the button located on the flat end of the charger 3 times, pausing for 1 second between presses.
12-22-2021 17:17
12-22-2021 17:17
12-23-2021 05:43
12-23-2021 05:43
I have the same problem and am so disappointed. I had another Fitbit and wore it out so I bought a new one. I’ve had it about 6 months and never wear it now because it is always dead and Won’t track my sleep either. The cheaper one worked so much better.
12-24-2021 05:36
12-24-2021 05:36
