07-30-2023
07:13
04:41
07-30-2023
07:13
04:41
Hi - I was wondering if you can charge your Luxe with a standard wall charger, like a phone charger. I have been charging it on my Chromebook device, but want to see if there is the option to use a wall charger with a USB port. Thank you for your help!
07-30-2023 08:05
07-30-2023 08:05
Hi @julchek yes, you can. I do it all the time, but I make sure to take it off the charger and not leave it for a prolonged period of time.
07-31-2023 04:44
07-31-2023 04:44
Hi there, @julchek. Thanks for stopping by in the Fitbit Community Forums.
Totally! Nevertheless, please keep in mind @Odyssey13's advice. 🙂
Tips to best charge Fitbit trackers are:
For charging purposes, your charging cable or your base station can be plugged into any USB power source, including but not limited to:
07-31-2023 06:32
07-31-2023 06:32
Thanks @Odyssey13! That's good to know!
07-31-2023 06:34
07-31-2023 06:34
Excellent - thank you, @MarreFitbit ! This is very helpful to know!
