Hi, @Gmore76 , if you rely on auto tracking of your exercise (which uses Fitbit SmartTrack to automatically detect and log your exercises) it will not calculate your distance. It will give you the total distance for your day, but it will not give you distance for any individual activity.
If you want to have your distance tracked on an individual exercise then you have to use the Exercise App on your Fitbit Luxe and start and stop your activity manually, using the app. That is the only way to have distance calculated. If you have your phone with you and activate the connected GPS system, then Fitbit will use that to report your distance. If you do not connect to GPS on your phone, then the Luxe will calculate the distance by multiplying your estimated stride length multiplied by the number of steps.
I hope this helps. Please post again if anything is unclear or if you need any help in how to start an exercise using the exercise app on your Luxe. Welcome to the forums!
