01-19-2022 14:32
01-19-2022 14:32
Curious to know if the Luxe Classic Band will loosen a little with wear? I recently upgraded from the Inspire HR and wore the small band but I am finding the size small band that came with the Luxe is a tad smaller and less comfortable.
Has anyone noticed if it loosens a bit with wear?
01-19-2022 15:28
01-19-2022 15:28
Hi @SheSaidDestroy I've had my Luxe for close to six months and find the classic band to be softer than my Alta HR. It does seem to loosen a bit with time, but nothing unmanageable. Mine is the large size.
Best Answer01-19-2022 15:48
01-19-2022 15:48
Thanks @Odyssey13! I definitely don’t remember how my Inspire band fit from the box but I do know after wearing it for awhile, it felt bigger than what the Luxe does now (out of box today) on the same hole, same size band. Appreciate your reply! 🙂
