06-21-2021
01:58
08:35
06-21-2021
01:58
08:35
Hi helpers!
I’m looking to buy my first fitbit and choosing the Luxe. If I buy the black one and then the silver Gorjana bracelet strap, will the casing from the black watch match the silver bracelet?
does anyone have any images to view because the one online shows the silver bracelet with a silver watch casing which I can’t find how to buy!
thank you!
Best Answer06-21-2021 08:35
06-21-2021 08:35
Hi there, @SShah2205. Welcome to the Community Forums. I'm glad to hear you're interested in getting our newest Fitbit Luxe.
Regarding your inquiry, the Platinum Stainless Steel gorjana bracelet comes all in platinum, including the space where you insert the Fitbit Luxe tracker. The tracker itself is black, but once you insert it into the gorjana bracelet it will be cover in platinum (except the screen) just as shown here https://www.fitbit.com/global/us/products/accessories/gorjana-parker-link?sku=180MLGD
Hope this answers your inquiry.
Best Answer06-28-2021 01:20
06-28-2021 01:20
Thank you, I did purchase it and it’s beautiful but the bracelet does not sit flush into the actual watch
is the bracelet strap faulty?
06-28-2021 03:15 - edited 03-20-2024 10:34
@SShah2205 Please confirm that you're attaching the bracelet as it's described below:
If you still see that there's a gap between the tracker and the bracelet, please attach a photo so I can go from there.
In order to add a photo to your reply please:
Hope that helps.
06-28-2021 04:41
06-28-2021 04:41
Hello
Thank you for the quick reply. I have indeed fitted it correctly and heard the click but it just doesn't sit flush. I am unable to load images as the grey pop up box does not appear and if I try to paste an image in it says "you do not have permission to upload images". Can I send the image another way?. I hope something can be done to resolve this as I'm worried the strap will fall off when I'm walking.
Thanks
Seema
06:56
07:04
06-28-2021
06:56
07:04
I will be returning the stainless steel band as it comes apart in the presence of any metal chair arm, or car door. Poor design for $80.00.
Moderator Edit: Format
Best Answer06-28-2021 07:06 - edited 03-20-2024 10:34
@Lianerose @SShah2205 Thanks for the details provided. We‘re taking into consideration your comments and sentiments with regards to our products and services.
The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
Best Answer07-04-2021 14:01
07-04-2021 14:01
Hi Maria
I contacted the online chat help and spoke to someone called Mae. She advised a replacement would be sent to me but then the form she sent me didn't allow me to select the option of the "platinum stainless steel" Luxe watch. So I emailed her back but since have had no response and that's a week ago now. My case number is 41558208. Please can someone update me on what's happening otherwise I will need to return the watch and Gorjana strap as clearly it's faulty.
Thanks
Seema
