09-01-2022
10:21
14:31
09-01-2022
10:21
14:31
This is my 3d Fitbit but the Luxe is the SLOWEST to sync using the app. Why is that? I get the following display regularly: “Syncing your Luxe….sync is taking a while, sit tight”. Sometimes it take lab:60-:90 seconds to sync. WHY?
09-02-2022 21:17
09-02-2022 21:17
I use an iphone and it takes forever to sync with the luxe, the same with the Luxe I got my mum (iphone user as well). It has been like this for a while now and no amount of restarts of luxe or phone has ever helped. I'm not sure if this is just an iphone problem or it happens to both android/iphone users.
09-01-2022 14:34
09-01-2022 14:34
Hi there, @SpaceGuyBiff. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Luxe. I understand where your concern is coming from.
While reading your post, I was wondering if you are using the same mobile phone you used with the previous Fitbit devices? If so, I'd suggest making sure none of those Fitbit devices are still linked to your phone's Bluetooth settings as this may be causing some connectivity issues with your Luxe.
With the above being said, please try the following:
Hope this helps.
09-02-2022 09:44
09-02-2022 09:44
09-02-2022 21:17
09-02-2022 21:17
09-03-2022 02:15
09-03-2022 02:15
Hi SpaceGuyBiff,
This is my 2nd Luxe in 3 months and amongst other problems I have the same as you.
Happy that you got a discounted price (I didn't) because you can stand on your head to fix issues that reappear in a couple of days.
Tried all that messing that MarreFit suggested...no joy. But then, you shouldn't have to. Apart from looking good the Luxe is rubbish.
Hope that you get a sleep score, I don't have that either.
This is my fourth and last Fitbit, we don't purchase these products to do homework to find how they work.
Good luck.
09-03-2022 02:25
09-03-2022 02:25
Hi,
I'm an Android user and have the same problem but it only began 2 wks ago. Odd that, I've had the Luxe for 3 months.
Tried the suggested fixes from MarreFitbit, no joy.
Good luck and happy if that is your only problem.
09-03-2022 05:59
09-03-2022 05:59
Totally agree but I don’t think it’s an iPhone problem. I think it’s totally a Fitbit problem.
09-03-2022 06:04
09-03-2022 06:04
Wow sorry to hear that you have had all that trouble. I have really enjoyed my Fitbits. I got rid of my Inspire because the display was terrible in full light so I thought the Luxe would be good. Luxe has a great display but syncing time is ridiculous.
09-17-2022 19:12
09-17-2022 19:12
Same here--iPhone but had the Luxe for several months where it was working more flawlessly than any Fitbit ever has; now all of a sudden just today it has stopped syncing automatically and takes forever to sync manually. It is my 4th Fitbit too, using them since 2016, and every time there's a problem like this I think about switching to a product that actually works without having to do the constant research on why it's acting funky... then it'll fix itself at some point and I'll manage to forget about the headaches till the next time. Would be nice if they could just, you know, work dependably.
09-18-2022 03:46
09-18-2022 03:46
