07-16-2021
14:19
03:37
07-16-2021
14:19
03:37
My screen has suddenly gone blank and will not switch back on. I put it on charge (although the app said it had medium charge) I have tried resetting the Fitbit logo flashes on and just as quickly goes off. I have removed the Luxe from the app and tried to reconnect but the app is now not recognising the luxe and of course I can’t switch the Luxe on. So fed up only had this a couple of weeks, it is really disappointing, any suggestions or shall I just return this and ask for my money back ?
07-17-2021 03:43
07-17-2021 03:43
Hi there, @Mcdodia. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Fitbit Luxe prior to posting here. We‘re taking into consideration your comments and sentiments in regards to our products and services.
Since you've exhausted all steps we could've provided here in the forums, the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
07-22-2021 10:12
07-22-2021 10:12
This happened to me today. Used it for a swim on swim mode so was water locked, working fine after then noticed about 2 hours later screen is blank and won’t sync or even be found. My Luxe is only about 3 weeks old. Did you get any feedback from Fitbit?
Best Answer07-22-2021 12:49 - edited 03-26-2024 12:19
Hi there, @Sunniesusie. Welcome to the Community Forums. Thanks for sharing the details about the issue with your Luxe.
If your device got wet, it’s important to take it off and dry it well before putting it back on. On the other hand, if your device has come into contact with any liquid other than fresh water, you should clean it with fresh water and a soap-free cleanser and dry it with a lint free-cloth.
If you've done the above but to no avail, please try restarting your Luxe. For instructions, see How do I restart my Fitbit device?
If the restart doesn't work either and your watch hasn't vibrated for the restart process, I'd recommend trying the steps below:
Best Answer07-23-2021 01:10
07-23-2021 01:10
Thanks, I always keep a towel by the side of the pool and dry it as soon as I’m done timing. I don’t think it’s the pins that need cleaning as it’s only a few weeks old. It restarted after I charged it last night (although wasn’t flat when it turned off) but has screen is blank again this morning after a few minutes of being off charge. Will try a reboot.
Best Answer07-23-2021 03:11 - edited 03-26-2024 12:19
@Sunniesusie I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
10-05-2021
11:02
11:06
BraulioFitbit
10-05-2021
11:02
11:06
BraulioFitbit
This happens to me daily. I have to reset it every day. I tried contacting support and I got no help from them. I have had this luxe as soon as it came available. As I said everyday I have to reset it. To get it going
judy
Moderator Edit: Personal info removed
11-16-2022 13:27
11-16-2022 13:27
I also had this problem, when I put the fitbit on water lock mode it was impossible to get it back to normal. I’m not sure what you’re supposed to do, but what worked for me was changing the background on the app. You can of course change it back again.
