06-21-2021
20:43
06:31
06-21-2021
20:43
06:31
I’ve turned on notifications, and I can read them on my Luxe, but the luxe doesn’t vibrate like my Alta HR did when I received texts or calls. How do I get it to vibrate?
06-22-2021 06:35 - edited 01-07-2024 07:39
Hi there, @Abuelitita. Welcome to the Community Forums. Thanks for sharing the details about the inconvenience with your Fitbit Luxe.
As a first approach, I'd recommend to make sure Do Not Disturb and Sleep Mode are turned off on your Fitbit device. For more information, see How do I navigate my Fitbit device?
When the do not disturb setting is on:
When sleep mode is on:
Sleep mode turns off automatically when you set a sleep schedule. For more information, see Adjust settings
You can't turn on the do not disturb setting and sleep mode at the same time.
If the issue persists, see Why didn't my Fitbit device alert me?
Hope this helps.
Best Answer06-22-2021 06:35 - edited 01-07-2024 07:39
Hope this helps.
