06-28-2021
08:15
03:34
06-28-2021
08:15
03:34
Just got my Luxe, and I'm finding that, after a week of testing, the GPS does not reliably track my bike rides. Location Services is set to Always for Fitbit app, I'm syncing my Luxe regularly without trouble, Bluetooth is on, GPS is turned on within the Bike section of the Luxe itself. Sometimes it connects, sometimes it says No GPS signal, sometimes it says Trying to Connect (or similar). Any ideas how to get this to work? It's one of the reasons why I upgraded to a GPS-capable Fitbit.
I also tried turning off Map My Ride and other things that may use the GPS simultaneously - any idea if that's an issue? (Not that it helped to turn it all off.)
Thanks!
Best Answer06-29-2021 03:37 - edited 03-20-2024 10:44
Hi there, @BikeWalk. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Fitbit Luxe before reaching out.
Verify the following requirements; then try the troubleshooting steps if necessary:
See if GPS connects after each step:
Hope that helps.
Hope that helps.
Best Answer07-07-2021 08:41
07-07-2021 08:41
Ive done all that you said in your reply. It isn’t connecting at all to GPS.
the luxe worked well the first week but now it won’t connect.
my walking exercise is off & frustrating
what can be done to fix this
Best Answer07-07-2021 09:31 - edited 03-20-2024 10:43
@Bobbyboy69 I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
