06-18-2021 14:22
06-18-2021 14:22
Bought a gorjana Luxe for my wife and it looks gorgeous but the bracelet doesn't connect flush with the Fitbit device. It leaves a sharpish edge that could catch on things. Is this normal? Would be a perfect device if not for this little quirk.
11-16-2021 05:29
11-16-2021 05:29
I agree! Mine fell off and was never found again. The Gorjana link is a flawed product, and Fitbit will take no responsibility for this! That 35% discount they offered is no discount at all. COSTCO, Target, and others offer the Luxe at lower prices!!! I guess Fitbit really doesnycare about their customers…it’s just lip service.
06-21-2021 01:52
06-21-2021 01:52
Hi twopercent
Did you buy the luxe black strap and then the gorjana bracelet separate to attach? does that look ok with the black casing and silver bracelet? I’m about to purchase but worried it won’t look nice!
Best Answer06-21-2021 08:57
06-21-2021 08:57
06-21-2021 09:28
06-21-2021 09:28
I noticed mine can look a little loose sometimes. If I apply a small amount of pressure to it that has helped push it in the rest of the way. I haven't had it catch on anything, though mine isn't coming out far enough that I think it could.
06-28-2021 01:19
06-28-2021 01:19
Mine is the same - did you ever get a resolution from fitbit for this?
06-28-2021 14:15
06-28-2021 14:15
06-28-2021 14:32
06-28-2021 14:32
Hi! No I purchased the gorjana edition that comes with the pink band and gold gorjana bracelet. The pink bracelet connects very flush without issue, but once switching to the gorjana it was not able to connect flush.
I have not heard anything from Fitbit yet though I have not made any contact other than this post to see if it's a widespread issue. I'd like to get a replacement band but sounds like the same issue will occur 😞
06-28-2021
15:50
11:58
DavideFitbit
06-28-2021
15:50
11:58
DavideFitbit
Same issue here
I have reported to Fitbit but have not had resolution. At this point, I think it needs to be returned as it appears to be a faulty design. If I get a response, I will post it. No issues with the pink band on my end either; it's just the clasp on the gorjana doesn't stay flush and eventually, it wiggles loose and the bracelet falls off.
06-28-2021 16:32
06-28-2021 16:32
06-29-2021 02:28
06-29-2021 02:28
Try contacting them again. I did and they will send me a replacement to try I hope so maybe try again and see what they say
07-06-2021 18:47
07-06-2021 18:47
Same here. Really sucks because I really like how it looks!
07-07-2021 04:24
07-07-2021 04:24
Same here - pink fits perfectly, gorjana comes out a bit on both sides of the device. It hasn't fallen off...yet.....
07-08-2021 07:58
07-08-2021 07:58
Exactly the same with the steel mesh band. Does not sit flush at all- gap of around 1mm both sides and the strap parts wobble around until they fall out.
Only reason I bought the Luxe as I loved the silver band. 😞
And I can't seem to be able to send it back 😞
Hope you all have better luck!
07-08-2021 08:54 - edited 07-08-2021 08:54
It took about a week for Fitbit to get back to me about returning my Fitbit Luxe which isn’t fitting properly to the silver mesh band (their form didn’t allow for my colour). I am just waiting for their courier to collect it. Frustrated I will be without a Fitbit for a week or so now.
07-08-2021 18:07
07-08-2021 18:07
Same. I am concerned about the poor connection between the gorjana link bracelet and the device. I haven’t had it fall off, but I feel it’s just on the verge all the time. I can’t really enjoy it because I feel like I'm just waiting for disaster.
I, too, do not have this problem with the silicone bands.
Is this just normal for all the metal attachments? Or should I be making a complaint/return/exchange??
07-08-2021 19:00
07-08-2021 19:00
07-08-2021 23:56
07-08-2021 23:56
I asked this when I complained to customer service. They indicated they would send me a new Luxe that wouldn’t have the issue. It was a surprise as I had assumed the issue was with the mesh band.
Best Answer07-09-2021 01:20
07-09-2021 01:20
Hoping to hear about this issue too. Looking to update from my alta HR to luxe however hesitant because this issue with the luxe bands. I do not wear any rubber Bands as i find them unconfortable and plan on only wearing them with the link and or mesh bracelet for the luxe aswell. I only wear my alta with the Milanese Bands, only Bands i can sleep with.
if is likely that fitbit will make adjustments to the design or is it - it is what it is??
07-09-2021 01:40
07-09-2021 01:40
I contacted customer service by phone and they will exchange it because it's part of the guarantee. Waiting for the return label now.
Best Answer07-09-2021 13:22
07-09-2021 13:22
