08-30-2021
13:03
05:22
08-30-2021
13:03
05:22
How do I change my main goal from steps to distance
once synced it turns back to steps
08-31-2021 05:31 - edited 08-19-2023 07:22
Hi there, @PDK01. Welcome to the Community Forums.
As @Apples_e has suggested, please try changing your Mail Goal directly from the Fitbit.com dashboard.
If you goal isn't changing yet, please try logging out and logging back in to the Fitbit app. Then, follow the steps steps:
For more information, see How do I track my health and fitness goals with the Fitbit app?
Also, please make sure that your Fitbit app is up-to-date and that your phone is syncing properly with your Luxe. If you're running into syncing difficulties, see Why won't my Fitbit device sync?
08-31-2021 03:38
08-31-2021 03:38
Try using the fitbit dashboard instead of the fitbit app. Click in the settings for luxe and you should be able to change the main goals from there.
