04-16-2022
07:13
08:00
04-16-2022
07:13
08:00
My Charge2 displayed time when I moved my wrist, but the only way I can get the Luxe to display anything is when I have to tap on the face. Will it not automatically display with the wrist movement? Is there a setting ti fix this?
Best AnswerYou probably have Screen Wake in manual mode; if not that, you are in Sleep Mode. Access both in Quick Settings by swiping down from main clock face.
Hi there, @BlondBec. Welcome to the Community Forums. Thanks for the details provided in your post about the issue the inconvenience with your Luxe.
As @JohnnyRow has mentioned, have you made sure that the screen wake feature is enable? If you haven't done so yet, please go to your quick settings and check if the screen wake has been accidentally been turned off. To do so, swipe down from the clock screen to access the quick settings. Here you can change whether the screen turns on when you turn your wrist. For more information, see How do I navigate my Fitbit device?
If you cannot change the screen wake setting, it might be because your Luxe is in Sleep Mode. When the sleep mode setting is on:
To turn off Sleep Mode, please swipe down from the clock face on your watch to access the quick settings. You can now try switching the Screen Wake from "Manual" to "Auto".
Hope that helps.
That doesnt work. When i tap the wake up screen to change from manual to auto it does nothing. I see the setting to wake up the screen but it just wont come off of manual.
@MIperson wrote:That doesnt work. When i tap the wake up screen to change from manual to auto it does nothing. I see the setting to wake up the screen but it just wont come off of manual.
Read my post above - Sleep Mode.
