04-24-2022
08:05
06:31
04-24-2022
08:05
06:31
How do I enable voice cues? I have it turned on already.
04-25-2022 06:40 - edited 02-20-2024 03:16
Hi there, @DivineDiogenes. Welcome to the Community Forums. Thanks for making sure you've turned all settings already.
To properly receive voice cues from the Fitbit app, please check the steps below:
For more information, see How do I use GPS on my Fitbit device? and How do I track my activity with my Fitbit device?
04-25-2022 21:40
04-25-2022 21:40
Just to clarify there are no voice cues on Luxe or any other Fitbit devices. What you have on your Luxe are visual cues every some km, some miles, some minutes, some calories amount.
The procedure described by @MarreFitbit applies to the Fitbit app in your smartphone. Bear in mind that if you decide to walk/run using the app as suggested you can actually leave your Fitbit at home as the heart rate will not recorded (and consequently calories will be everything but accurate since not based on heart rate.
