01-23-2022
07:50
04:03
01-23-2022
07:50
04:03
Best Answer01-24-2022 04:05 - edited 08-10-2023 03:55
Hi there, @Mama_Fran. Thanks for stopping by in the Community Forums.
Please note that when a specific exercise is not available within the exercises we offer, we suggest to use "Workout" (which is a generic catch-all for other types of exercise). Once you finish the activity, you can rename the activity to desired exercise/activity. Please note that the amount of calories burned vary from the exercise you're performing and due to the heart rate tracked by your Luxe.
Note that the information to enter will change depending on the nature of the exercise. To give you an example, if you change from "Workout" to "Dance", it won't remove the calories but will add distance or steps as the main stat to be displayed, this happen depending of the activity you are categorizing. However, your the data already tracked will be still counted for your daily totals.
For more information about how to do so, see How do I add, edit, or delete Fitbit data and activities?
