08-11-2022 16:53
08-11-2022 16:53
I previously had an inspire 2, and there was a way to set hours for when clock face automatically lit up with movement and hours it did not (during sleep).
I cannot find a way to do this on my Luxe. I only find a way to manually turn it off every night, which would be a pain and likely forgotten.
is there a way to set hours for when the display lights up with movement and when it lights up manually?
I can’t find this answer for Luxe on these forums. Thanks.
Best Answer08-11-2022 18:50
08-11-2022 18:50
@nettle26 , A warm welcome to the Community! Thank you for your question and taking the time to search on the Community!
The Luxe as well as the Inspire 2 has some features as the ones you described.
To access them, swipe down from the clock screen. You 'll see the Quick Settings.
DND mode - Don't Disturb mode.
Sleep mode -Sleep mode turns off automatically when you set a sleep schedule
Screen wake - When you set screen wake to Auto , the screen turns on each time you turn your wrist.
When you set screen wake to Manual , firmly tap the screen twice to turn it on.
Hope this helps you further.
Best Answer08-12-2022 08:28
08-12-2022 08:28
Thank you. I saw each of those features, but that doesn’t answer my question. I don’t know how to set hours for when the display comes on automatically and when it is manual. The watch only allows on/off for sleep mode, not specific times. If I set sleep goals within the app and turn on sleep mode, will the display be in sleep mode during those hours and auto mode outside of those times?
08-12-2022 13:43
08-12-2022 13:43
@nettle26 I don’t have my Luxe on my account right now, so I'm including a link to the Luxe manual for quick reference. Go to your Settings app on the Luxe > Quiet Modes > Sleep Mode > Schedule > Interval. I hope setting the start and stop times is self-explanatory. I never used an Inspire 2, so I looked at its manual. It doesn't have "Quiet Modes" in its path. I bet that's what caused the confusion.
Laurie | Maryland
