07-11-2021
14:23
19:44
07-11-2021
14:23
19:44
Hi ,
Is there a case that I can use for my Fitbit luxe ?
Regards
SS_2021
Best Answer07-11-2021 19:47 - edited 03-20-2024 10:47
Hi there, @SS_2021. Welcome to the Community Forums.
For the time being, there's no case you can use with Fitbit Luxe. However, you can switch the bands. To see the bands available for Fitbit Luxe, click here https://www.fitbit.com/global/us/products/accessories
See you around.
07-12-2021 04:50
07-12-2021 04:50
@SS_2021 Are you asking about a case so you can wear your Luxe as a clip-on? From experience, I can tell you that Fitbit won't create a clip for a device unless it has an on wrist/on clip setting. The Luxe doesn't have this setting. You should check on Amazon from time to time. Third party companies make clips for the Charge 3 and 4. I think it is just a matter of time before someone makes a clip for the Luxe.
Laurie | Maryland
