09-25-2021 18:42
09-25-2021 18:42
Through a wellness program at work, I purchased a Luxe and enjoy it. However, I don't wear it on my wrist during the day due to my constant keyboarding. My old One works great so I use that it during the day and wear the Luxe at night especially for sleep tracking. I also bought an Inspire 2 to wear with the clip function once the One dies. When I was setting up my Inspire 2 tonight, I get a message that you can only have either the Luxe or Inspire 2 working unless I disconnect one and pair the other one. Up until a few days ago, I had a Luxe, Alta HR and One all synching on the FB app. Is it true that I have to disconnect the Luxe and pair the Inspire 2 at least once or twice a day? Is this progress for Fitbit to allow only one device at a time?
09-25-2021 19:11
09-25-2021 19:11
Unfortunately that is a limitation applying to newer devices.
From Can I use more than one Fitbit device with the same account?
Best Answer09-25-2021 20:15 - edited 09-26-2021 12:25
With all the progress in technology, I thought Fitbit might be smarter than that. I hope my One lasts for a very long time since I get extra steps while wearing the Luxe on my wrist while working. Thanks for relaying the message. Now I have to return the Inspire and will tell the company that using both at the same time won't work.
Best Answer09-25-2021 20:26
09-25-2021 20:26
I suppose you realize this, but the Inspire 2, as well as with the clip, can be worn on wrist for sleep tracking.
09-26-2021 12:27
09-26-2021 12:27
Thanks for reinforcing this, been thinking the Inspire 2 might meet my needs better than the Luxe will.
