01-10-2025 03:18
01-10-2025 03:18
I've had the luxe for 2 years and tbh it was really good for a long time, however since the last update, it has become virtually unusable.
I can charge it up to 100%, but come the end of a day its either dead or has a low amount of battery left.
Putting it on charge sometimes gives a misleading battery % oftern saying its higher then it is, even syncing it with the app doesn't work.
I'm now finding myself charging everyday, I've tried everything suggested on hear turning notifications off, screen awake off ect, but still the issue persists.
I have been with fitbit for years, I had a zip to begin, but it kept resetting the step counter, got an inspire, didn't record some steps, and battery issues, so I got a luxe, was good at first, but now it's not. I've looked at other fitbits, and I'm reading about the same issues with battery % draining too quickly, so unfortunately I'm having to look at a different make of fitness tracker.
01-10-2025 20:31
01-10-2025 20:31
I have the same issues.
Best Answer01-11-2025 01:17
01-11-2025 01:17
It's frustrating tbh,
I get that rechargeable batteries degrade over time, but this has only happened over the last couple of months, so I know its got nothing to do with turning different things off, and even when I've done that, I still have the same issue. I've had it where I've charged it to 100% before going to bed, I wake up and it's dropped down to 25%, put it back on charge, it says 70% upwards, reset it and still says the same, put it back on when fully charged, gone to work and by the time I've finished work it's dead....
Best Answer01-11-2025 21:06
01-11-2025 21:06
