02-07-2022 23:41
02-07-2022 23:41
The luxe battery level on my phone app states 51%, however on the device it states 15% and I got an email that the battery is low. I rarely check my emails or the device for the battery level, but I look at it everyday when I check my phone. I’d like my phone app to sync.
Best Answer02-08-2022 05:25
02-08-2022 05:25
@SunsetRunner I suspect you are an iPhone user. This is a known bug with the iOS app. You can get the correct battery charge by force quitting the app, then re-opening it. I know that the Luxe font is very small and it is hard to read the battery level on the screen. You will need to force quit/re-open daily, or more often, to follow your battery charge on the app.
Laurie | Maryland
Best Answer02-08-2022 08:25
02-08-2022 08:25
