10-28-2022
08:51
09:12
10-28-2022
08:51
09:12
HELP my Luxe not tracking my step propertley
Best Answer10-28-2022 09:14 - edited 12-12-2023 10:01
Hi there, @Domineck. Welcome to the Community Forums. Thanks for the details provided in your post about the inconvenience with your Luxe.
If you feel that your step count and distance are inaccurate, confirm the following are correct in the Fitbit app:
Since we use height to estimate your walking and running stride lengths, you may want to measure and manually adjust these values if your legs are longer or shorter than average. For more information, see How does my Fitbit device calculate my daily activity?
Sometimes, when you start walking, your steps may not update on your device right away. After about 10-15 continuous steps, you'll notice the steps catch up and start updating in real time with each step you take. For more information, see: How accurate are Fitbit devices?
On a side note, please make sure that your Fitbit Luxe is up-to-date. For more information, see How do I update my Fitbit device?
Hope that helps.
Hope that helps.
Best Answer01-17-2023 14:57
01-17-2023 14:57
Hi MarreFitbit. None of your suggestions work, and there seems to be a lot of us with the same issue. I've tested Wrist settings, dominant hand, height, stride lengths etc, with no effect. I've made a video to demonstrate the issue here https://youtube.com/shorts/75s2hCQQ-9U?feature=share
As you can see, even small movements of the hand and wrist results in steps being counted in excess. Today I've been working at my desk, and my iPhone counts 2200 steps, the Fitbit has counted 7753 steps...
