07-03-2022
07:26
17:08
07-03-2022
07:26
17:08
So Luxe was great for 8 months but has suddenly stopped tracking steps correctly, out by 50%. The heart rate monitor is giving way too high numbers when standing. Have tried everything including re installing as a new device.
07-04-2022 17:13 - edited 11-19-2023 03:42
Hi there, @Patchykat. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Luxe. I understand where your concern is coming from.
As a first approach, I'd recommend restarting your Luxe. For instructions, see How do I restart my Fitbit device?
If your Luxe is still not tracking your steps accurately, confirm the following are correct in the Fitbit app:
Since we use height to estimate your walking and running stride lengths, you may want to measure and manually adjust these values if your legs are longer or shorter than average. For more information, see How does my Fitbit device calculate my daily activity?
Sometimes, when you start walking, your steps may not update on your device right away. After about 10-15 continuous steps, you'll notice the steps catch up and start updating in real time with each step you take. For more information, see: How accurate are Fitbit devices?
As for the heart rate, please check What factors can affect my heart-rate reading o my Fitbit device?
Hope that helps.
Hope that helps.
07-09-2022 03:18
07-09-2022 03:18
Thanks for your reply. I have restarted the fit bit several times and have also reinstalled it as a new device. The heart rate is now more accurate but the step counter does all sorts of things! An example would be that it will get up to over 1,000 and then will go back down to 400! At the end of the day I average about 50% of steps done. It will register correctly for a short period and then won’t register anything for a while…and doesn’t catch up the missed steps when it does. Everything else seems to be working correctly.
07-09-2022 05:54 - edited 11-16-2023 10:48
@Patchykat I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
