Luxe is showing the wrong time after charging it
ANSWERED
After charging I find the clock is displaying the incorrect time. (out by half an hour) How can I correct this?
1 BEST ANSWER
Accepted Solutions
Thank you for your assistance. I had synced the Luxe but since writing my concern my son suggested I delete the device and reinstall. I’m happy to say this has sorted the issue. Thank you though for your kind attention
Sent from Yahoo Mail for iPhone
2 REPLIES 2
Hi there, @marionrodgers. Thanks for stopping by in the Fitbit Community Forums. It's sad to hear that your Luxe is showing the wrong time after charging it. I'll be glad to help you with this.
As a first approach, may I ask if you already synced your device? Please note that the time will be wrong if your Luxe hasn't recently synced as your Fitbit device uses the time of the device you're syncing with. To make sure your Fitbit device has recently synced, go to your Fitbit app and tap the Today tab, and then tap Devices.
If by any chance you run into syncing issues, please see Why won't my Fitbit device sync?
If the issue is still not solved, but you can confirm that your Fitbit device is syncing,  I recommend changing your time zone to a completely different one, sync your device, put the correct time and sync again.
