07-21-2021
17:31
17:10
07-21-2021
17:31
17:10
I like receiving a notification on my Luxe when I'm getting an incoming call. But I also get a notification when I make an outgoing call, which I'm finding quite annoying. Is there a way to switch this off just for outgoing calls?
07-21-2021 19:14 - edited 07-21-2021 19:14
Hi @Jaimb I have a Luxe myself, but despite having notifications on and getting the for incoming calls, I've not gotten any for outgoing calls. I'm using Android. Have you tried restarting your Luxe, as that normally takes care of a glitch.
07-22-2021 07:39 - edited 03-15-2024 06:18
Hi there, @Jaimb. Welcome to the Community Forums. Thanks for sharing the details about the issue with your Luxe. I understand how annoying that can be.
As @Odyssey13, I myself have a Luxe and Versa 3 and neither of the two have that behavior. Please try @Odyssey13's advice and see if the restart does the trick.
If the issue persists, I'd recommend setting up notifications again. To do so, follow the steps below:
07-24-2021 23:09
07-24-2021 23:09
This didn’t help. I still get a notification saying “Active Call” when my outgoing calls have been answered. It doesn’t go away until the phone call ends, or I swipe across the luxe screen (which I can’t do if my other hand is using the phone).
I tried restarting the device. I also tried updating the luxe. I also tried forgetting the Bluetooth device, then connecting again. Still the same thing happens.
I’m using an iPhone
07-24-2021 23:53
07-24-2021 23:53
Happens on both my iphone and my mums iphone as well so you are not alone 🙂
Best Answer08-02-2021 08:48
08-02-2021 08:48
I have the similar problem. During any active call, the Luxe vibrates every 5 minutes. It seems like some setting intended to distinguish an active call, for whatever reason. It is driving me crazy, I'm on the phone all day for work and it is a huge distraction and annoyance. My Inspire HR did not do this. Can it be turned off somehow?
09-01-2021 17:35
09-01-2021 17:35
I’m having the same problem. Why does the luxe think I need to be reminded every couple of minutes then I’m on a call? I know that I’m on it. I don’t need this reminder. Infuriating “feature.” As a bonus, this also seems to be destroying the battery life.
09-01-2021 17:37
09-01-2021 17:37
^that, not then
and by destroying I mean that I was on the phone for a total of about 2 hours today, which dropped the battery from about 79% to 6%
09-24-2022 11:09
09-24-2022 11:09
Not the answer that works. How would an active call notification even be needed? It needs to be removed. It’s annoying when on a call.
