05-31-2022 12:39
05-31-2022 12:39
My Luxe lights up when not worn / moved. It is not set to "always on". I will leave it on a counter overnight (I don't sleep in it). When I go to pick it up in the morning, sometimes it is already on - the font is a rainbow color instead of its usual solid white. Other than this - it seems to work normally. Screen goes blank and it comes on when I raise my wrist to look at it. Font is white. This happens about once or twice a week. Any ideas?
Best Answer06-01-2022 16:38
06-01-2022 16:38
Welcome to the Fitbit Community, @Liz756.
Thank you for letting us know that your Fitbit Luxe lights up when not worn.
If you haven't done so, please restart your Tracker by following these instructions.
In addition, you can try a different clock face to see if the issue gets resolved.
Hope this helps.
06-09-2022 06:07
06-09-2022 06:07
I have reset a few times, and the issue is still happening. I will try a different click have now to see if that helps. It only occurs every few days, so testing is a bit slow. I've also checked that no alarms are set
Best Answer06-09-2022 12:15
06-09-2022 12:15
Thanks for your response, @Liz756.
If you followed the instructions above without luck, the best way to get help for this problem is to chat with us online or give us a call. Please click here to get connected.
Have a nice day.
