12-23-2021 05:12
12-23-2021 05:12
Luxe is not tracking my aerobics workout. I have looked at all the suggested solutions here and still.
Do you have any other solution? Alternatively, I need to return this watch. Aerobics is thebmain exercise I perform.
12-23-2021 09:28 - edited 09-01-2023 08:11
Hi there, @ThatoK. Welcome to the Community Forums. Thanks for the details provided in your post about the inconvenience with your Luxe. I understand how important is to you to track your aerobics.
When a specific exercise is not available within the exercises we offer, we suggest to use "Workout" (which is a generic catch-all for other types of exercise). Once you finish the activity, you can rename the activity to Aqua Aerobics. Please note that the amount of calories burned vary from the exercise you're performing and due to the heart rate tracked by your Luxe.
Note that the information to enter will change depending on the nature of the exercise. To give you an example, if you change from "Workout" to "Run", it won't remove the calories but will add distance as the main stat to be displayed, this happen depending of the activity you are categorizing. However, your the data already tracked will be still counted for your daily totals.
For more information about how to do so, see How do I add, edit, or delete Fitbit data and activities?
