08-06-2023 10:10
08-06-2023 10:10
I have changed screen face, restarted it and nothing helps. It's useless the way it is. I've only had it about a month and a half.
Best Answer08-06-2023 13:29 - edited 08-06-2023 13:29
@TK54 , A warm welcome to the Community! Thank you for your message and for your efforts.
Support confirmed me that you already contacted them .
Keep working with Support to avoid any confusion. They'll take care of you.
Best Answer08-14-2023 14:23
08-14-2023 14:23
I'm having the same issue. It's very frustrating !
Best Answer08-14-2023 14:44
08-14-2023 14:44
@Didistar , A warm welcome to the Community! Thank you for your message.
Did you already try to restart the Luxe and change the clock face?
Wie starte ich mein Fitbit-Gerät neu?
Wie ändere ich das Zifferblatt auf meinem Fitbit-Gerät?
08-14-2023 15:55
08-14-2023 15:55
Hi Juan
Yes, I did both these things. It was better for several days, but just started having problems again this evening.
Best Answer08-14-2023 16:48
08-14-2023 16:48
08-14-2023 16:54
08-14-2023 16:54
08-15-2023 14:40
08-15-2023 14:40
I am actually on my 3rd Luxe since May because of those issues. It started with my Luxe not syncing, even after all of the troubleshooting suggestions. Tech issued a replacement after my 3rd call in 2 weeks. That one worked for a few weeks, then the screen went black with green lines. More calls to tech, and they issued another refurbished Luxe which arrived today. It had a totally black screen, so I put it on the charger. It didn't buzz, or show any lights on the back or front. I left it on the charger for 3 hours, and still nothing. I have a call in to them now, but am about ready to try a different model!
Best Answer08-15-2023 15:41
08-15-2023 15:41
Best Answer08-15-2023 16:25
08-15-2023 16:25
Oh no! That stinks! I really like this luxe! I hope we can all get one that works!
