12-14-2022
17:53
03:51
12-14-2022
17:53
03:51
I've noticed that the screen becomes unresponsive for somewhere between 10 and 30 seconds at the following times during a tracked workout (possibly more):
I can't tap or swipe the screen to dismiss these notifications. Waiting for the screen to turn off and on doesn't work either. I need to wait for 10 to 30 seconds for the notification to be dismissed. This is a nuisance as it doesn't let me check other stats on the device.
Has anyone else encountered this? Any solutions other than turning off Lap tracking and Zone notifications?
Thanks!
Kevin
Best Answer12-15-2022 03:50
12-15-2022 03:50
Hi there, @kschach. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Luxe.
While reading your post I was wondering if this is happening all the time or you've noticed this to happen only when you exercise? I was having a similar trouble with my touch screen, thing was my fingers were too sweaty when I was trying to check my progress during my workout so I just started making sure to dry my finger before touching the screen and problem solved. Would you mind trying this in case you notice your fingers are too sweaty when touching your Luxe's screen?
However, if this is happening all the time (meaning you've noticed the screen is also unresponsive when you're not exercising), I'd recommend restarting your Luxe by following these steps How do I restart my Fitbit device?
Hope this helps.
Best Answer12-15-2022 13:25
12-15-2022 13:25
