01-26-2022
20:49
05:11
01-26-2022
20:49
05:11
Hi, is there a trick in swiping the luxe screen to activity? very often i get as far as the alarm or notification and cannot even get back to the clock. it is so frustrating. i might add it isnt all the time, but everytime i need it. Can i totally disable the alarm and notifications and countdown, all i want is activity. Thank you anyone who replies.
01-27-2022 05:12 - edited 10-30-2023 15:17
Hi there, @DiBann. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Luxe. We‘re taking your comments and sentiments in regards to our products and services into consideration.
Please restart your Luxe as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Hope that helps.
Hope that helps.
