01-03-2023
09:53
15:47
01-03-2023
09:53
15:47
I woke up and my Fitbit screen won’t display . The battery is dying quickly. What should i do? You said we should wear it to bed… now i don’t know what happened during the night that stopped the screen. I have tried to restart but no result. i can see its still working through the app. But i can’t see anything on the watch itself. Help please
01-06-2023 15:49 - edited 10-14-2024 10:32
Hi there, @Gsalma. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Luxe before reaching out.
To better assist you, please make sure you've restarted your Fitbit device as suggested here How do I restart my Fitbit device?. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
As for the battery draining too fast, Can I extend my Fitbit device's battery life?
Hope that helps.
01-06-2023 23:32
01-06-2023 23:32
01-07-2023 04:52 - edited 12-12-2023 10:06
@Gsalma I appreciate you had followed the tips and recommendations provided above.
I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
01-10-2023 09:14
01-10-2023 09:14
try the reset button on the USB adapter 3 times (1 second in between each press). make sure the usb is plugged into power as you do it.
01-10-2023 09:19
01-10-2023 09:19
01-13-2023 08:00
01-13-2023 08:00
I got a replacement. Thank you so much. I had missed my watch so much.
