Luxe stopped working after swimming with it
I swimmed in a chlorine pool in my fitbit on Saturday and now on Monday it is still not working as it should. The screen is not visible and it is showing multiple colors
4 REPLIES 4
Hi there, @GiselleSolomon. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Luxe.
f your device got wet, it’s important to take it off and dry it well before putting it back on. On the other hand, if your device has come into contact with any liquid other than fresh water, you should clean it with fresh water and a soap-free cleanser and dry it with a lint free-cloth.
If you've done the above but to no avail, may I know if your Luxe vibrated during the restart process? If it didn't, I'd recommend trying the steps below:
  • Clean the charging contacts on the back of your device and the pins on your charging cable using the instructions in How do I clean my Fitbit device?
  • If the error "insufficient power source" appears on your device's screen, remove other devices plugged in to your power source, or plug your device in to another source.
  • Try a different USB port or a UL-certified wall charger.
  • Check the alignment and try reconnecting your device to the charging cable. For more information, see How do I charge my Fitbit device?
  • Restart your Fitbit once again.
Have you tried using water lock.
Hi.  I'm new to FitBit Luxe.  What is water lock?
Water lock is a special mode that enables water to not press any buttons on your Fitbit
