03-27-2023
06:37
11:16
03-27-2023
06:37
11:16
Although there is plenty of charge in my Luxe it stops recording my activities, so I haven't a clue how many steps I have done
So frustrating!
03-27-2023 11:24 - edited 11-03-2023 05:18
Hi there, @Sukiesuspot. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post. I understand how you must be feeling.
As @Gr4ndp4 has suggested, please restart your Luxe as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
If the issue persists, may I know how you track your activities? Do you use SmartTrack or use the Exercise app? Also, I'd like you to please clarify if your Luxe is turning off due to a battery short life? If this describes your issue, please see Can I extend my Fitbit device's battery life?
03-27-2023 10:44
03-27-2023 10:44
Hi, @Sukiesuspot, welcome to the community, I understand your Luxe did work but has stopped, You tell us it's charged so I assume it is still paired to the Fitbit app on your phone. I recommend you restart your "Luxe", this How to Restart Fitbit Luxe (Reboot) - YouTube video demonstrates the process,
Let us know how you get on.
Cheers
Gr4ndp4 | UK
04-02-2023 19:01
04-02-2023 19:01
I'm having a similar issue where I'm tracking on my wrist, my tracker just locks up gives me a black screen, and is unresponsive. plugging it in wakes it up, but I still lose what I was tracking and any steps until i can plug in. I started also logging using the app because the tracker was crashing/locking up. I have reset it as suggested above to no avail- it still crashes.
04-05-2023 05:13
04-05-2023 05:13
Hi, @Sukiesuspot & @blondechick80, as you are still experiencing difficulties after following @MarreFitbit advice I suggest you talk to "Customer Support" Use the chat facility or phone for a prompt response. It's a good move to make a note before you start your call including the steps you have taken & the results, the make & model of your cellphone, and where & when you bought your Luxe as you may still have the benefit of the "warranty".
I hope this helps, let us know how you get on by posting here again.
Cheers
Gr4ndp4 | UK
