07-23-2023 10:45
07-23-2023 10:45
Sometimes my Luxe will not accurately record the time I go to bed. For example, last night I got into bed at 10:30 pm and was asleep by about 11:00 pm, but my Luxe today showed I got into bed at 1:30 am and fell instantly asleep.
This has happened before and I have edited that sleep log to reflect the correct bedtime, but it then eliminated all the sleep data for that night.
07-24-2023 15:00
07-24-2023 15:00
@courtcar , A warm welcome to the Community! Thank you for your message.
Please try wearing the Luxe a bit tighter during your sleep. If the tracker senses movement although your heart rate gets lower, it might "think" that you are still awake.
Another thing to check is to have the settings as normal and not sensitive. What's the difference between the normal and sensitive sleep setting?
07-26-2023 10:16
07-26-2023 10:16
Same problem for me. Usually about 3hrs off from when I go to sleep. I've tried every suggestion I can find. Worst fitness tracker I've ever owned. I've owned 2 Fitbits and a Halo and this Luxe is the worst as far as data accuracy. Actually thing about tossing it.
07-26-2023 12:00
07-26-2023 12:00
@SunsetRunner , A warm welcome to the Community! Thank you for your report and efforts.
Could you please describe what you already tried, so that I don't ask you again, if not needed?
Did you tried the tips on my previous post?
07-30-2023 16:38
07-30-2023 16:38
Luxe Fitbit was already on Normal. Tried wearing it tighter to bed but last night it said I went to bed at 12:30 am when I actually went to bed at 10:30 pm.
07-31-2023 05:58
07-31-2023 05:58
I have the same problem and it shows Sleeping at 5am when I go to bed at midnight. Yet it shows the Wake up at the correct time.
Setting is Normal. I changed the time zone from Automatic to Manual, then back to Automatic.
07-31-2023 06:03
07-31-2023 06:03
07-31-2023 06:16
07-31-2023 06:16
08-05-2023 04:29
08-05-2023 04:29
So what now? [Crickets]. No recommendations? Just SOL?
Not very happy with Fitbit
08-06-2023 10:50 - edited 08-07-2023 11:19
Hi everyone. Thank you for your messages and efforts.
If you already tired the steps described by @SunsetRunner , then the next step should be to contact Support.
They'll provide you further assistance.
