08-13-2024
21:25
08:44
08-13-2024
21:25
08:44
My daughter's fitbit luxe which she received for Christmas will not charge. We have cleaned all the charging bits with alcohol and cotton swab and the actual wall port does work. We do not have another charger compatible to test with. Any ideas on what to do?
Hi there, @Lorax88. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your daughter's Luxe is still not charging. I understand your concern, I will do my best to help you with this!
Please note that sometimes a Fitbit doesn’t seem to be charging when actually the issue is that it has become unresponsive (this can happen if the battery has been allowed to discharge completely). I'd recommend putting it on to charge on a charging wire and outlet known to be working. Leave it on the charger for a good two hours, even if it doesn’t seem to be charging.
Nevertheless, please make sure you've followed all tips and recommendations provided here Why isn't my Fitbit device's battery charging?
In addition, find below some tips to best charge Fitbit devices:
For charging purposes, your charging cable or your base station can be plugged into any USB power source, including but not limited to:
Best AnswerHi @Lorax88 fill out the form - click to go there
Best AnswerHi Maria,
We've tried all the trouble shooting suggestions and none have helped.
It's as though the watch is completely dead.
What should I do from here?
