10-29-2021
00:30
04:12
10-29-2021
00:30
04:12
I lost the connection between my Luxe and my phone. My phone finds my device, connects but then I have ' a message went wrong' I have tried all the steps mentioned. restarting Bluetooth, rebooting the device etc . What can I do more before I restart my luxe and lose all my data? Thanks
10-29-2021 04:05
10-29-2021 04:05
Hi, @olympe, welcome to the community. If you "restart" your device in the "settings" menu you will not lose your data as this prompts a soft reset. A hard reset occurs if you go to "device info"> "clear user data". You may find these articles useful How do Fitbit devices sync their data? and Why won't my Fitbit device sync? I also suggest you check the Fitbit app on your phone, ensure all permissions are allowed and any battery-saving function on your phone is disabled for the Fitbit app. This last prevents the phone from treating the Fitbit app as non-essential and putting it to sleep.
I hope this helps but if you are still stuck please post here again.
Cheers
Gr4ndp4 | UK
10-30-2021 04:17 - edited 03-28-2024 18:11
Hi there, @olympe. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Luxe before reaching out. I understand where your concern is coming from.
Please take all information provided by @Gr4ndp4 into consideration in order to solve your issue. Nevertheless, if you continue to have connectivity issues after follow those tips and recommendations, I suggest trying the following:
If you can't get started with your Luxe, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Best Answer06-19-2022 17:58
06-19-2022 17:58
Same thing is happening to me! My versa won’t connect to my phone and I did all the steps mentioned! What can I do ? My Fitbit it’s not even 4 months of use
Best Answer06-20-2022 07:34 - edited 12-19-2023 08:55
@romero.angelica Welcome to the Community Forums. I appreciate you had followed the tips and recommendations provided above
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
