02-27-2025
14:58
07:20
02-27-2025
14:58
07:20
Why have these Fitbit Luxes not been recalled? My Fitbit does not hold a charge. I have to charge 3 times a day! Doesn’t capture sleep at all and steps are incorrect. It has been restarted, removed and added back countless times and nothing helps. These fitbit Luxes are terrible and obviously by reading this forum I’m not the only one that has problems with the Luxe. The older models were much more reliable!
02-28-2025 08:34
02-28-2025 08:34
Hi there, @Emorbe. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that the battery of your Luxe is not lasting as expected and that it's also not tracking your data accurately. I understand your concern, I will do my best to help you with this!
As a first approach, please bear in mind that as all rechargeable batteries age, they deteriorate to some extent and an older device will need to be charged more often than a new one. The best way of minimizing this effect is to avoid deep discharges of the battery. To maximize the overall life of your Fitbit device's battery, ideally keep it between 20-80%. Many people find that a daily battery boost works best ( e.g. giving it a 15 minutes charge while you are showering in the morning). For more tips and recommendations, please make sure you've tried all tips and recommendations provided here Can I extend my Fitbit device's battery life?
About your sleep data, I recommend considering the following in order to get sleep stages:
For more information, see What should I know about Fitbit sleep stages?
Regarding the steps not being accurately, may I know if this started to happen recently?
02-28-2025 08:34
02-28-2025 08:34
