03-31-2024
05:37
04:27
03-31-2024
05:37
04:27
My Luxe is less than 2 yrs old. 3 days ago it was charging and I noticed it displayed a red x inside a white circle symbol (or vice versa)😬 I figured that was tbe typical death of a high tech device sign. It didn't want to turn on either..long story short....after it turned on I noticed the time was wrong. I couldn't sync it on the app ..tried everything so I chose to forget it on android ...now my phone struggles to find it again and when Bluetooth does manage to find it ..it absolutely can't pair to it now. No advice I have tried works. So basically fit but tracks and does everything but sync pair and know the correct time
03-31-2024 05:50
03-31-2024 05:50
Hi @JeniGitsAbitFit Not syncing is awful when it happens. Have you tried the suggestions in THIS Help Article on syncing? If you are trying to set up your Tracker in the app again and are having problems then try THIS one. I hope you are back working with your fitbit again soon!
Helen | Western Australia
03-31-2024 14:19
03-31-2024 14:19
Same here. So frustrating! No fix is working.
04-01-2024 04:33 - edited 04-01-2024 04:34
Hi there, @JeniGitsAbitFit @lagomez. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Fitbit devices are still not syncing. I understand how you guys must be feeling, I will do my best to help you with this.
In addition to the steps you've done so far, I'd recommend trying the following in the order listed:
With the steps above, what I want you to do is to pair your Fitbit device first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Once you manage to pair and sync your Fitbit devices, the time (and date) should be corrected. Keep in mind that your Fitbit device may show an incorrect time if it hasn't synced or has been unpaired from your Fitbit account. Your Fitbit device uses the time of the device you're syncing with.
Best Answer04-02-2024 16:05
04-02-2024 16:05
Hi!
I have the exakt same problem! My Luxe is 2 years old. And the last 3 days it's no loger sync with the app or pair with bt on my phone. I'm going nuts over here. I've tried everything!!
04-02-2024 22:51
04-02-2024 22:51
I am experiencing the exact same thing. Has not been able to sync for 10 days...
04-09-2024 17:23
04-09-2024 17:23
You want us to remove ALL bluetooth saved devices????
Is that the solution or is this a workaround until a new firmware version is available?
04-10-2024 13:29
04-10-2024 13:29
I'm so frustrated! My scale won't work either. It's 2 months old!!!
