01-05-2025
05:21
07:13
01-05-2025
05:21
07:13
can no longer pair luxe with phone, S8. have turned bluetooth off and on. have restarted phone. have turned phone off and left it and then turned it on. have restarted luxe. have moved fitbit account to gmail. still won't pair.
01-05-2025 06:56
01-05-2025 06:56
Hi @carolleecooper you need a minimum of Android 10 to use your Fitbit. click to learn more
01-05-2025 11:57
01-05-2025 11:57
I have the same issue as carrolleecooper. New phone, reinstalled app, restarted everything and I still can't get my luxe to sync. I am getting a Low energy report when I try to connect via bluetooth. Watch is fully charged. I went through the entire list of troubleshooting steps so I am at a loss. Appreciate any suggestions. thnx
01-10-2025 08:45
01-10-2025 08:45
I'm having all the same issues as you. I have a newer phone and have tried all the suggested trouble shooting steps. My phone and Lux still will not sync. Very frustrating 😕
01-10-2025 12:40
01-10-2025 12:40
I have the same problem. The phone is showing that a luxe is available to blue tooth, but it wont pair. Was fine until a few hours ago. I ve done all the steps suggested. I had the same problem late October but it was fixed when some update was made.
02-01-2025 12:35
02-01-2025 12:35
None of the troubleshooting steps I've found in the various threads helped in my case (for my wife's Luxe). What did work was factory resetting ("clear data" on) the Luxe itself. Can't be done from the app of course with sync not working. Instructions here: https://www.androidauthority.com/how-to-factory-reset-fitbit-1092426/#charge5luxe. I used a 3rd party link because I could only find the reset instructions via linked app on fitbit.com.
Apparently, data on the Luxe itself was sufficiently corrupted that it prevented bluetooth sync. After reset, normal pairing procedure works, though I had to enter pairing code twice and ignore an error claiming pairing failed even though it didn't.
I can't update most other threads on this board because they are frozen.
02-02-2025 05:34
02-02-2025 05:34
I had the same problem and tried everything that everyone suggested and it still didn't work called Fitbit and the guy talked me through what to do..All I had to do was install my luxe as if it was a new device and the problem resolved within one minute...hope this works for you
02-02-2025 06:15
02-02-2025 06:15
02-02-2025 07:31
02-02-2025 07:31
02-04-2025 18:52
02-04-2025 18:52
Tried everything to pair and sync my fitbit. It was updating my steps but the time was wrong. Finally had to do a factory reset on my watch. Swipe down, settings, device info, clear user data, hold button for 3 seconds. Then set up your fitbit. This will wipe out any unsynced data.
