10-15-2021
03:53
03:57
10-15-2021
03:53
03:57
My sleep score will not update. I have rebooted my phone, restarted my Luxe, attempted to synch multiple times. It still will not give me a score. What do I do NOW?
10-15-2021 03:58 - edited 10-02-2024 09:08
Hi there, @SunsetRunner. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Luxe before reaching out. I understand where your concern is coming from.
Keep in mind that you must see sleep stages in order to see your sleep score information. Please swipe left on the Sleep Score graph, here you can see information about your weekly sleep average and sleep duration. To get more detailed information, see What's sleep score in the Fitbit app?
With that in mind, I recommend considering the following in order to get sleep stages:
For more information, see What should I know about Fitbit sleep stages?
Hope this helps.
10-15-2021 05:01
10-15-2021 05:01
The issue is there is no sleep score to swipe left ON. My Fitbit was not worn loosely at all. I have logged out, deleted the app, I have reinstalled it, I have synched directly with the cable, I have restarted my phone, but nothing is working. It worked perfectly fine the first night. Do I need to replace this device?
10-15-2021 05:02
10-15-2021 05:02
It was clearly used. I could see when I went to bed and shut it off. It shows over six hours of use, but will not generate a sleep score.
10-21-2021 09:21
10-21-2021 09:21
Swipe up for Sleep Score.
Does a Sleep Score show in the Fitbit App?
Do you have Sleep Stages?
