Luxe won't swipe anymore
Hi my fitbit luxe has been fully charged, Working and syncing great. Then one day it was having a hard time swipping. Since then it won't swip at all. Will respond to double tap for waking up, will charge, will sync. I have restarted it via cord many times, I have changed clock faces heaps. I let it die in my draw for a week only to re add it and see it will not swipe still. Can someone please help! It may be just a year old. I loved my luxe. I need go fix it.
5 REPLIES 5
Hi, @Rheacapilli04, welcome to the community, have you checked that "water lock" is not engaged? This disables the touch screen.
Give the Lux a firm double tap (I use the side of my thumb). If it's locked another double tap unlocks it. You may be surprised by how firm you need to be.
Let us know how you get on.
Cheers
Gr4ndp4 | UK
Hi there, @Rheacapilli04. Welcome to the Fitbit Community Forums. I'm sorry to hear that your Luxe screen is still not swiping despite the steps you've tried so far. We're here to help! @Gr4ndp4 Thank you so much for advice!
I've seen you contacted our Support Team after posting here and they've already assisted you. If the steps that our team has provided did not work, please feel free to contact them back for further assistance. Since you already have a ticket open with them it'd be easier to continue the follow up on this matter with them directly.
Thanks in advance!
Unfortunately it is definitely not stuck on water lock. As it would
normally say it is. But also double tapping very hardly does nothing. Only
tapping will turn the clock face screen on. No other motion will work.
Quite upsetting. I really want it to work again.
Hi, @Rheacapilli04, thanks for the update, as you are talking to Customer Support they will be the best way forward. I think you've considered all the options you can carry out yourself. Depending on who you bought your Lux from and your location you may well have the benefit of Fitbit's return and warranty policy. - Fitbit Help Center
Good luck.
Gr4ndp4 | UK
Did you get any further as mine is doing the same, just over 12 months old. Can view everything in the app but not on the watch. Have restarted via charging cable and 3 if us have tried tapping to ensure water lock is off. No joy. Any suggestions welcomed.
