10-05-2021
15:13
04:29
10-05-2021
15:13
04:29
Hi, I’ve had my Luxe since it’s release and it’s never synced with my iPhone. My prior Fitbit (charge 3) was fine. The lack of sync was annoying but only just started being a problem because the Luxe now displays the wrong time!
I’ve followed all the troubleshooting steps and nothing has worked. Please help
10-05-2021 15:26
10-05-2021 15:26
Hi @Banana83 you need to have at least iOS 13 to work well. Read this article for troubleshooting the syncing problem - click to go there.
10-06-2021 00:13
10-06-2021 00:13
Hi, I have iOS 15 (was using 14 previously) and have gone through all of the troubleshooting steps.
10-07-2021 04:33 - edited 06-21-2024 11:41
Hi there, @Banana83. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Luxe before reaching out. We‘re taking your comments and sentiments in regards to our products into consideration.
Since you've already exhausted all troubleshooting steps for this issue and you've also make sure that your iPhone is running iOS 15 as @Odyssey13 has suggested to check, know that the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
10-07-2021 20:06
10-07-2021 20:06
Having same problem. Frustrating!
10-08-2021 00:08
10-08-2021 00:08
I just received my brand-new Luxe and tried to sync it four times on my brand-new iPhone 13 Pro with iOS 15-point something. After four attempts, it would not sync. I then read the instructions to turn off Bluetooth in iPhone settings and then turn it back on. Mission accomplished! It worked. Now my Luxe is synced, and now it is also updating the Luxe software at the time of this writing. All is well! Try turning Bluetooth off and on. It worked for me.
10-08-2021 04:31 - edited 03-03-2024 03:29
@DCJAM Thanks for stopping by in the Community Forums and sharing the steps that worked for you. 🙂 I'm glad to hear that you managed to solve the syncing issues.
@SQuinn1 It's nice to see you around the Community Forums. I understand how frustrating this can be, but I'm sure I can help. As @DCJAM has suggested, please follow the steps below:
If you still If you still have trouble, please see Why won't my Fitbit device sync?
10-10-2021 05:50
10-10-2021 05:50
Also, one more thing to add. THIS IS VERY IMPORTANT. I forgot to remove my olf Fitbit Alta setting when I was trying to update my new Fitbit Luxe. You must remove the old Fitbit from the iPhone so that the new one can update. If you have two Fitbits syncing at the same time, the update feature won't work for your new Fitbit. Learned this after repeated attempts. I'm all up to date now and loving my new Luxe. It is so comfortable. I much prefer it to my clunky, uncomfortable Apple watch. Fitbit Luxe is my new everyday accessory!
