09-12-2022
16:38
06:43
09-12-2022
16:38
06:43
Every day I have to restart my Lux, uninstall and reinstall, and or restart it to get it to sinc properly and transfer data to the app. Quite frankly I’m getting tired of this. Is there a way to keep this problem from happening every day? Fitbit needs to send me a new Fitbit that actually works properly.
Best Answer09-13-2022 06:48
09-13-2022 06:48
Hi there, @schnauzr. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Luxe before reaching out. We‘re taking your comments and sentiments in regards to our products into consideration.
In addition to the steps you've done, please try the following:
If you still If you still have trouble, please check the following requirements:
Afterwards, please try the following:
Reopen the Fitbit app after each step until your device syncs:
Hope this helps.
09-13-2022 06:48
Hope this helps.
Best Answer09-14-2022 02:15
09-14-2022 02:15
Thank you for your reply. I have done all of the things you suggest pretty much every day, every time my Luxe Fitbit doesn't sinc to my phone. Again this morning I uninstalled it, reinstalled it to get it to sinc to my phone. The point I'm making is, I shouldn't have to uninstall and install my Fitbit every day. Obviously there is something wrong with the Fitbit that it's not sincing or transferring data properly to my phone.
09-14-2022 07:50 - edited 06-03-2023 11:43
@schnauzr I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Best Answer03-12-2023 03:55
03-12-2023 03:55
None of these steps solve the issue. My Luxe takes so long to sync that it usually errors out multiple times before it eventually does. The mythical ‘auto-sync’ feature is a distant dream.. I’d like it to at least manually sync without difficulty, as a basic requirement.
Customer support is not helpful on the matter either, they usually give up / end the session once my device has synced, determining that the issue to be resolved - completely missing the point that it shouldn’t be this difficult every single time!
03-13-2023 11:45
03-13-2023 11:45
I am having the exact same issue. My luxe will not sync with my android Device 😞
