05-14-2023
16:33
06:36
05-14-2023
16:33
06:36
My Samsung S23, is not linking to Fitbit Luxe. Is this a fixable issue?
Best Answer05-15-2023 04:35
05-15-2023 04:35
Hi @LBauer26 It should be fixable. Are you trying to set up for the first time? If so try THIS Help Article on Set up problems. If it has worked beforeand has stopped syncing, then try THIS Help Article on syncing issues.
Helen | Western Australia
05-15-2023 06:45 - edited 06-07-2023 08:25
Hi there, @LBauer26. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Luxe.
If the steps recommended by @NellyG don't work, please try the following in the order listed:
With the steps above, what I want you to do is to pair your Luxe first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Best Answer05-15-2023 09:38
05-15-2023 09:38
My Luxe is having the same problem with my TCL 30SE. I have tried the steps above and it still won't pair. Now it will not set up at all, so it isn't tracking anything.
