04-23-2024
16:26
14:59
04-23-2024
16:26
14:59
We tried reinstalling the app but that didn't help. What else can we try?
04-23-2024 17:26
04-23-2024 17:26
I am having the same issue, it just started earlier today. I re installed the app as well. I'm on an android device.
04-23-2024 18:54
04-23-2024 18:54
I just spent time chatting with the Fitbit help desk. He talked me through restarting the watch. It may have worked. I’ll know better tomorrow.
Best Answer04-23-2024 20:38
04-23-2024 20:38
Best Answer05-04-2024 07:18
05-04-2024 07:18
I have this problem every morning. It’s been ever since Google bought out Fitbit!!! I’ve tried all the tricks suggested, but it appears it only syncs when Google tells it too. Appreciate any suggestions. Thanks.
05-04-2024 10:57
05-04-2024 10:57
Best Answer05-06-2024 17:43
05-06-2024 17:43
I’m having same issue! Frustrating.
05-11-2024 09:35
05-11-2024 09:35
Hi, I am having the same issue Luxe won't sync and it's showing the wring time also
05-11-2024 11:12
05-11-2024 11:12
Sorry, just to clarify, you delete the fitbit app from your phone and then reinstall it and it doesn't delete your saved info?
Best Answer05-13-2024 17:46
05-13-2024 17:46
I'm having the exact same problem. Any advise?
Best Answer05-13-2024 22:58
05-13-2024 22:58
I tried all the trouble shooting tips. Even did a webchat for over an hour.
The last thing that worked was deleting the Luxe from my fitbit account and then adding it again. Then it worked !
I did loose all my data that hadn't synced though, but it got it
Best Answer05-14-2024 11:59
05-14-2024 11:59
Best Answer05-14-2024 22:02
05-14-2024 22:02
I'm having the same problem! The last time my phone synced was 5/13/24. Today, 5/14/24, I noticed the time was incorrect. At 5:00 pm it said the time was 10:24. I tried syncing and it wouldn't sync. I went to turn off Bluetooth and I noticed my Luxe was missing from paired devices. I spent the next 3 hours deleting the Fitbit app, reinstalling the Fitbit app, turning off/on Bluetooth, pair the Luxe to my phone, syncing again and nothing worked. Now I can't even pair my Luxe to my phone. PLEASE FIX!! I rely on my Fitbit and need it working.
Best Answer05-14-2024 22:13
05-14-2024 22:13
Hi
I know how frustrating this is.
Have you tied plugging into the charger and then pressing the button on the charge unit 3 times in quick succession, which should then make the fitbit logo appear on the watch face ?
The other thing I tried was removing the Luxe from my fit bit account, and then re adding it.
Then it would pair and would sync.....
Best Answer05-15-2024 06:44
05-15-2024 06:44
