Luxe won't track my steps
ANSWERED
Hi My Fitbit Luxe hasn't recorded my sleep overnight and is now saying 0 steps on the device and the app. I have reset it but it still the same 0 steps even though I am walking around. Does anyone know how to fix it thanks
1 BEST ANSWER
Accepted Solutions
Hi there, @kel782002. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Luxe before reaching out.
If you feel that your step count and distance are inaccurate, confirm the following are correct in the Fitbit app:
Since we use height to estimate your walking and running stride lengths, you may want to measure and manually adjust these values if your legs are longer or shorter than average. For more information, see How does my Fitbit device calculate my daily activity?
Sometimes, when you start walking, your steps may not update on your device right away. After about 10-15 continuous steps, you'll notice the steps catch up and start updating in real time with each step you take. For more information, see: How accurate are Fitbit devices?
Regarding the sleep data, I recommend considering the following in order to get sleep stages:
  • If you slept in a position that prevented your device from getting a consistent heart-rate reading or wore it too loosely. For best results, wear your device higher on your wrist (about 2-3 finger widths above your wrist bone). The band should feel secure but not too tight.
  • If you used the Begin Sleep Now option in the Fitbit app (instead of simply wearing your device to bed). For more information on automatic sleep tracking, see How do I track my sleep with my Fitbit device?
  • If you slept for less than 3 hours.
  • If your device’s battery is critically low.
For more information, see What should I know about Fitbit sleep stages?
1 REPLY 1
